Fidanza flywheel friction disc, can you flip it?
Im doing the clutch on my b16 swapped ek and i was wondering if i can flip the friction disc on the flywheel. Finding a replacement is impossible, they don't even have them on the fidanza website. Anyone have any experience.
Re: Fidanza flywheel friction disc, can you flip it? (killercannible)
flipping it is not a good idea, it will not sit very flat. Call up fidanza, if you send it to them they can replace it.
Re: Fidanza flywheel friction disc, can you flip it? (Runnerdown)
Well, its a time thing. I need the car tommorow, what do you mean it won't sit flat, it hasn't warped it just has some heat marks and wear.
Last week i was feeling that my clutch is slipping and when i put down the gear box,i was surprised,my fidanza 6 spuck disc has worn to the extreme level as well as the fidanza flywheel friction disc.Me too wanted to resurface it but then i thought that it'll be too thin when a new disc will press on it.And also resurface the friction might bear big issues such as the screw,you'll have to enlarge the hole where the screw will sleep on and that is risky.
Fortunately my used oem clutch kit as well as the flywheel were used.Meanwhile i contacted fizanza for replacement insert steel and they responded with a quote price of $100 plus international shipping.So,they do have it in stock.
