need help trying to find info....
i need to find a website if there even is one made that lists every part number on the car for a 92-95 civic si hb
if there is one that would be great
thanks
thanks
Re: need help trying to find info.... (crazyguy)
keep getting this error
java.sql.SQLException: Server configuration denies access to data source
Re: need help trying to find info.... (Probot)
http://www.slhondaparts.com/
- It has pictures that ownz both those links posted (yes, they are bigger, and bigger is better).
As far as a java exception for MySQL - what jack nuts controls a database with a java front end??? I don't think I've ever even heard of that before (I'm a software engineer). Holy shitttttttttttttt
omgwtfbbq!!!
I'm gonna go around today replacing all the PHP front ends I can find w/ java ones because I hondapartsonline said it was possible!! - Well maybe not - but I got research to do now...
- Peace, good luck, slhondaparts.com has everything you need - you'll have to get used to the categories at first - but those categories are global (like something marked in the fuel system, will still be marked in the fuel system in a helms manual). Once you get used to the rather awkward categories, like 99.9% of parts are on there - you can even buy replacement blocks and ECU's for absurdly high amounts of cash.
omgwtfbbq!!!
Honda-209
10-05-2009 12:28 AM
