fpr making loud noise
my stock fpr is making loud spraying like noise but the sound is not continuous. its like tsssst.....tst...tst..tsttst....tssssssst..... haha thats the best i could describe the sound. it sounds like someone just randomly messing around spraying spraypaint.
my car runs rich as hell and the injectors are fine i tested em. how could i tell if the fpr is f*cked? got really bad gas mileage and really bad idle sometimes going really low like it wants to die out, im thinking inconsistent fuel pressure. inputs would be much appreciated
Re: fpr making loud noise (el_toro_de_magnifico)
up!
in addition to that, the idle is low and sometimes goes near zero but after i run the car hard going up to vtec and then letting it idle it idles like a champ then after a few seconds it idles real bad. what could this be? a little help ht
pull the vacuum hose off your FPR, see if the inside of the hose is drenched with fuel. if it is, you have a leak in your FPR diaphragm and it needs to be replaced.
AnAccordIsForever
07-13-2006 11:52 AM
Sketch_hs
07-01-2003 08:57 PM
