97 sol with GSR swap
ok so i just bought a 97 sol with a GSR swap the only prob is the motor is OBD1 and the Car is OBD2A so im trying to wire it and i need to know how many plugs will be left at the end
pictures would be great and tell me colors of wires
Well, if you have left over plugs at the end, that means you are going to have a crapload of Check Engine Lights You should probably get a conversion harness.
Re: (scion)
ok i got it to run but it has a bunch of check engine lights and redlines at 6500 RPM will a jumper harness and a OBD1 ecu fix these problems
ooo and can i run a obd1 02 sensor it plugs in the plug so idk thats y im asking
Ganja_Green_559
09-11-2011 01:29 AM
