need help asap
need help asap
ok, iam having a problem with my timing belt. it keeps slipping towards the middle of the cam gear. everything is tight and been triple checked and the only thing keeping it on is the plastic pieces that go around the belt (i only have the bottom one). if someone could help me with this asap it would be appreciated. thanks and God bless.
Re: need help asap (z6hatchboy)
no its not skipping teeth. when we put it on the camr gear and tighten everything and i start the car the belt will just move to were the belt is a little more then half on. we have tightened everything but the belt still isnt very tight. you think i need a new tensioner (cant spell)?
Re: need help asap (heavyhittersclub)
got it from autozone and iam guessing it was the right belt. i guess i can check and see if someone has one i could borrow to see if i had the same problems. should i check for anythign else?
-Gambit-
11-13-2005 04:13 PM
B2FiNiTY
15
09-10-2003 07:47 AM
IdahoHybridAccord
03-27-2003 05:15 PM
IdahoHybridAccord
03-27-2003 01:37 PM
