Help!!! my 93 delsol has a missfire in idle
Ive been having a problem with my 93 delsol 1.5 it has a rough idle and then it starts to miss as the rpms drop, i did a complete tune up fuel pump, filter, spark plugs, wire, distr. cap and rotor and its still has a miss fire im thinking its either a vac. leak but i don't know where or low compression in that cylinder any ideas? its only in idle its drives great also the cylinder that has a miss is the 4th one the closest one to the timing belt Please help!!
Re: Help!!! my 93 delsol has a missfire in idle (les3525)
check your timing. and check vacume leak from intake manifold gasket. throttle body gasket. iacv. tps and map sensor o rings/gasket. perform a compression test.
with 1.5 d series non vtec engine. the compression should be
8.5:1~9.5:1 compression: 170-210 psi per cylinder
Re: Help!!! my 93 delsol has a missfire in idle (crazyguy)
is there any trick to checking for vac. leaks I just want to make sure I do it in a way so I don't miss anything? as for the compression test I will do that tomarrow I'm hoping that's not the problem cause would b a pain in the ***
DeCoY
06-21-2017 02:45 PM
jdmkid209
08-18-2010 06:56 AM
