eg with gsr ?
eg with gsr ?
so i have a 92 eg with a swapped gsr and i want to hit around the 200 whp mark what would be a good idea b esides boost. i have a boost option set up if i want it and my spending limit is about 1500 is there much i can do to reach this and still be a realiable dd?
Re: eg with gsr ?
CTR or ITR cams, skunk2 cam gears, higher comp Pistons, intake, good header, exhaust, skunk2 intake manifold (if ur going all motor), maybe MSD or something and a TUNE afterwards
if u wanna blow ur budget then get better valves, retainers and dual valve springs and throw in stage 2 cams
MiG-21 superfan
Re: eg with gsr ?
if the bottom end is in good shape, i think you should go with a properly ported head with upgraded springs, a big cam (within reason), ITR type intake manifold, a good tune and a nice header like SMSP. for 1500, i think you might have a tough time attaining your goals unless you can do all of your own tuning and headwork.
for what it's worth, and i hate using dyno numbers for anything other than comparing vs. a baseline while tuning...but, on jeff evans dynapack, my jdm gsr swap made 174/132 to the hubs with an apexi gt manifold to apexi n1, skunk2 intake manifold and power FC tune, nothing else.
walrus_07
02-02-2011 05:08 PM
futrhondaownr
10-11-2008 01:11 PM
