what engine harness to use in 94 civic b18b
ok i need to know what harness i should use, cars obdI and ecu is p75, engine is obdII integra b18b1 from 98
can i use obdI harness or shoudl i use obdII harness(reason i ask becase i see a sensor ontop the intake mani that i dont see on the older b18a's, i know both are plug and play
and could i use a auto harness for my 5 speed, and could i use a gsr harness or no
thankyou
thankyou
Seagull Management
Re: what engine harness to use in 94 civic b18b
'96 - '99 Integra 5 speed engine harness is your absolute best choice, direct plug-in everywhere. Use an OBD1 P75, P74 or PR4.
Umm if the ecu doesnt have a Knock sensor u can use OB1 wireharness. cause the Ecu isnt looking for the Knock.. i have a 99 B20B an it has knock sensor but i have a PR4 ECU an no issues. an im using a a SOHC wireharness actually
Hope thats helps lol
Seagull Management
OBD1 what? ECU yes, thats what I said to use in my previous post. Harness no unless you want to cut and splice several connectors or replace components with OBD1 versions. In anycase there will be no CELs (using an OBD2 ECU will throw several CELs however)
BoostJockey
03-12-2005 04:55 PM
