Need to decide on a suspenson..
Well gentlemen, ive narrowed my choices down to two brands which will be going on my 95 civic coupe..
they are as follows:
P.I.C.
either with adjustable dampers or non adjustable (still debating on that)
& which spring rate im going to use
8/6
10/8
10/12
12/14
14/18
OR
Koni Yellow's with GC (Ground Control)
Anyone have them on their civics? what are the pro's and con's i gotta make a decision soon
keep in mind, car will be boosted.. and i know that when u go higher with the spring rate u sacrifice ride quality.. so im trying to get the best of both worlds..
your thoughts?
Thanks.
P.I.C.
8/6
10/8
10/12
12/14
14/18
OR
your thoughts?
Thanks.
Re: Need to decide on a suspenson..
sorry i also forgot to mention that i will be changing my front and rear control arm bushings, front and rear shock bushings, front end links, steering rack bushings, transmission shifter stabilizer bushings (manual transmission only), ball joint boots and tie rod end boots, & rear trailing arm bushings all to poly
& some skunk2 LCA's
& some skunk2 LCA's
where the hell did u hear this..
broo
poly has been used for YEARS
i have never heard of anything like this before..
maybe in the US?
pic is great yet so is koni and gc plus a lifetime warreny on the konis,
filp a coin.
if you do go pic i wouldnt go higher then 10k/8k on the street.
filp a coin.
10/12k is pretty dang stiff. but the adjustable dampers could help out enough to make it berable.
good news is you could always change the springs for lower or higher rates.
You'll definitely want adjustable shocks, whether in a full coilover setup or Koni Yellows. I'm running Yellows with H&R Race springs and I love it to death. Great deal too.
turbojdmsol
Suspension & Brakes
10
04-06-2010 05:20 PM
civexspeedy
11-10-2008 09:11 PM
importdude2000
Suspension & Brakes
17
10-19-2006 09:07 PM
Blade_Irl
06-15-2003 07:08 AM
