Removing EK Sideskirts
I'm trying to take off my sideskirts on my EM1 to get access to the fender, but i'm finding it impossible to do. Helm's says you need to take the three clips out of the bottom and then there are more clips that need to be twisted, however, I cant get the three out of the bottom. I'm just using a flathead but I can NOT get these to pop out. do you have to unscrew them? Special tool? Twist them? Break them?
Re: Removing EK Sideskirts
yeah those are hard to get out sometimes.. I just try and pull it out with my left finger while unscrewing them with my right at the same time.. maybe youll get lucky.. or you can break them off then go and buy new ones at the honda shop. good luck
unscrew the plastic under stuff (i forgot whats its called) under the fender.. the screws nearest to the side skirts... then take off the 10mm bolts under the car bolted to the side skirts their should be 3 or 4 idk..prolly 3... then slide the sideskirt forward towards the front end and thats it i believe lmk if everything goes good
your talking about the 3 bottom screws under the side skirts right? yes they are 2 pieces just like the front bumper.. only difference is that you have to screw it on whereas the front bumper peices are pushed in..
Remove the clips under the side skirts, unscrew the screws in the front or back if there is, then push it forward towards the front of the car hard enough and it'll slide forward and come off.
thats not what I have.
and I would just pull it off and break them but I dont want to damage the skirt
H-T White Ops
There are screws at the ends in the wheel wells. Then there are the clips on the bottom, which are supposed to be easy to remove, but aren't. Then push the sideskirt forward and it will fall off the car.
There will be white clips left on the car. Twist to remove those. Slide them back onto the spots on the sideskirt. Line the sideskirt back up with the holes on the car and press it onto the car. Put the new clips on the bottom of the skirt and put the screws back in.
Redemption
12-07-2008 06:43 PM
civicseth
47
09-03-2008 02:36 PM
turnsignalandy
11
02-23-2008 06:15 PM
VTEC-DA
10-14-2002 12:27 PM
