skunk2 TB gets stuck even at 5.5k. unless i flick the pedal
1 Post
what can i do to fix this. i just went to walmart and other stores with parking lots and that **** is anoying. It gets stuck anywere2.5-5.5 and i have to flick the pedal for it to settle. i heard this is common. what do you guys do?
Re: skunk2 TB gets stuck even at 5.5k. unless i flick the pedal
might want to clean your throttle body with some cleaner. If that doesn't work theres a stop screw that you can adjust on the TB (adjust upwards), which is located under the spring.
i had this problem with an STR throttle body.
i took some 600 grit sandpaper and sanded the throttle body a LITTLE BIT around the top and bottom where the plate contacts it.
it fixed my problem.
notice LITTLE BIT. this may not be your problem, but it was with mine
1 Post
i thought about doing that, but first i'll shorten that spring that takes it back so it has a stronger pool.
