00 Civic EX - new honda owner needs help with idle
I just got a 00 civic ex and the car is almost brand new but the idle is wierd usually when still it stays at 1500 rpm when cold and when its going and i put it in nutral it stays at 2500 -2000 rpm until i make a complete stop then it drops to 1000 or sometimes a little higher does anybody know what it might be do too. thanks for your time
Re: 00 Civic EX - new honda owner needs help with idle
The stock 00 Civic EX does not have an FITV.
Any CEL codes?
Check whether throttle cable is adjusted too tightly and clean the throttle body.
Any CEL codes?
its most likely a vacuum leak, dont throw parts at it. Find out what it is. Leaks are really easy to find, either you can hear a really loud hissing sound or you can spray throttlebody cleaner around areas that could have a leak. careful tho, if there is a leak the engine will sputter (or completely stall), do it when the engine is colder, hot engine with combustible liquids might not be fun.
dillenbeck518
01-22-2015 09:27 AM
bigmeech
06-11-2014 04:50 PM
nismoracingsx
23
02-18-2014 04:32 PM
