newb tach question
newb tach question
I am helping a friend work on his car and he has a 94 civic ex with an H22a motor swap. im helping him install a tach and need help knowing the CORRECT (proper and safe) way to install the signal wire to the engine. I know you are supposed to tap into the negative side of the coil but it has an internal coil in the distributor. If anyone can help me that would be great thanks.
Re: newb tach question
ok thats the wire right under the windshield on the drivers side engine compartment right? how is the right and safe way to tap into that wire so that both the dash and aux tach works? thanks for the info.
open ur hood and look where the harness goes throught the firewall on the driver side by the the master cylinder and there a blue wire that in the engine harness but doesntconnect to anything it safe to tap into
great guys thanks a lot for all the info on this. im a mustang guy and its a lot easier on those. But i do have another question for you guy that you might know the answer to.
He has been noticing lately that the rev limiter in the car will sometimes engage at different RPM's. what could cause this to happen?
Tyson
40
06-04-2009 04:24 PM
