Timing Problem NEEDS HELP ASAP
HI i got a 95 civic coupe...i did a 95 integra ls swap to my car
and the timing was off...i couldnt get it to be on the right spot for it to run'
right at all after putting on a new timing belt and water pump...
i try everything that i could find on the net butta still couldnt get it to run right
some how its short on power and tourqe...
anyone that has any idea please help me out!!!
Re: Timing Problem NEEDS HELP ASAP
and when i adjust the dizzy the motor idle bad as hell
r u sure ur cams are aligning correctly cause when i did my friend's 94 ls timing i had to sweak the cam. Even though the cam is up, i still have to turn either the intake or exhaust cam by one teeth to make the car run right. DON'T KNOW WHY.
yea im sure that my cams are aligne correctly butta maybe ill try to do wat you did and see how its gonna run like..thanx btw
forcefedferio
08-23-2006 03:48 AM
