97 Civic HX Climate control illumination lights NOT WORKING!!!
Okay, So I've been spending all day trying to troubleshoot this.I've searched and searched and couldn't find a answer for it.So my climate control illumination lights aren't working for some reason.Everything else works Dimmer,Cluster Lights.Mode Select Lights.It's just the climate control illumination lights.I've replaced the bulbs and checked all fuses and plugs.None blown,Still nothing............
Re: 97 Civic HX Climate control illumination lights NOT WORKING!!!
Get a volt meter and see if you are getting power to the bulbs. Then check the grounds for continuity. Work your way from there back to the fuse box. i can't help you much more than that i am afraid.
itsJDMyo
14
11-30-2003 11:05 PM
