Smoke, Should I worry? Vid
Well i had not noticed this until today. I decided to wash the car and in the process I noticed some smoke. So I made a video.
Engine: B16a2
ECU: P2T
Mods:
HKS Hi Power cat back
Injen SRI
No catalytic converter
http://www.youtube.com/watch?v=d7H89B7zmN0
Engine: B16a2
ECU: P2T
Mods:
Injen SRI
Re: Smoke, Should I worry? Vid
I did a compression test and it was 180 in all 4 cylinders. I did noticed oil around one of the plug wires (the one that had the most oil on the plug) so my guess is that the valve cover seal needs to be replaced.
try the same thing reving it up after its warmed up to operating temperature. if it goes away then or is smoking less then its probably the valve seals. being your compression test came out high and consistent i would rule out the rings. was the compression test done warm or cold? and was this done at WOT? the numbers sound about right. to test the rings u would pour just a lil teaspoon or cap full of oil down each cylinder. repeat the compression test. if all your numbers go up drastically its usually an indication the rings are bad.
Teamdiesel
12
04-25-2006 06:21 AM
