Checking Dizzy O ring
96 Civic EX
I had the o ring done about 2 years ago.
I still have an oil leak in that area.
I was checking under the dizzy with a flashlight and I put my hand under it to check for fresh oil, I didn't come up with oil, does that mean it is not the cause of the leak?
Is there a way to know if the dizzy is leaking or not?
Mike Jones
Re: Checking Dizzy O ring
Valve cover gasket?
The O-ring is incredibly easy to replace, as is the valve cover gasket. If you feel it might be either, just go ahead and do them. Cheap fix.
Clean off the entire area. Check for additional leakage each time you fill up for gas, or once a week. The leak should expose itself.
