99 civlx 4dr Exhaust System Urgent Help!
What's going on guys...
Hopefully I can get some help on this topic and I can take care of this immediately.
The other night, I started my car up and right away knew something was up with the pipes. Either a weld cracked from years ago that I had done to seal up (I believe) part of the section 2 or sprunk a new leak.
Today I brought it in and where the bracket connects to the section1 looks a bit split. Spot weld or fully replace? I have no problem fully replacing the pipe (labor is no issue) if I can find the right deal. Used, brand new whatever it be.
THEN, we start to look back and my damn muffler snapped right off in between where it connects to the section 2 and the muffler itself. So I need a new muffler as well which is not the hard part. Found one at autozone? for about 70$
I get a price quote for sec1, sec2, muffler and all hardware. !!!!!$$$850$$$$!!!!!
Way out of my league and felt I was getting owned so dipped out immediately. Figured I could pull the parts together myself over the net and with your guys help and then bring it to my friends dads shop and have him do the labor at minor cost.
I seen nothing at all wrong with the sec2 and maybe he was just going for the full kill. I'm going to my friends dads shop this Saturday and am going to see what he thinks about the section2. It snapped after the connection to the muffler and right before the muffler itself, so I don't really see the need for a new sec2.
PLEASE HELP GUYS!!!! I'm newb when it comes to sourcing things for my civic!
Quoted - $503 for sec1
457 - sec2
65 - muffler (sounds about right)
gaskets hardware etc...rest of the total sum
discounted 25% comes out to $835 all said and done!
Please Help me make this cheaper!!!!
457 - sec2
Re: 99 civlx 4dr Exhaust System Urgent Help!
Are you asking whether the price estimates are fair (belongs in Value Thread at the top) or do you have a technical question? Please clarify.
Sorry, didn't know where to properly place this thread. Please move if it needs a new home. I just know this section gets the most traffic and would get noticed as some of the other subforums are pretty quiet.
Um...I guess both? Am I being ripped off AND need help finding the parts so I can do it on my own for cheaper. I always know work and parts can be had for cheaper, so I would bet anything that's priced rather high as they've always priced their work high.
I got mine from autopartswarehouse.com
from the cat converter back - everything, hangers, gaskets, pipes, muffler, it was like 300 with 2 day shipping.
You are not describing it right.
Is the header (exhaust manifold) cracked that is the section in the front of the car and for lx's the cat converter is attached.
If that is shot and then you need the rest of the exhasut back then 850 is not super out of line, a bit expensive.
Thanks for the reply moteg, I do appreciate it.
Not explaining it right...hmm
(back to front) muffler connects to sec2, to sec1, to the headers.
The section1 that I am speaking of that had a visible crack that they quoted me like $500 looked like so:
http://www.partsgeek.com/gbproducts/...ek+Google+Base
The section2 looked good to go and I think they said screw it lets go for the whole monty. I'm taking it to my friends dad who knows his stuff and will finalize if the sec2 needs to be replaced at all or not.
The muffler, there's no doubt about it that I need a new one. A blind person could see that crack lol
What is the closest to stock/oem muffler I could find? I'm going to see what's up with meineke tomorrow to see if they have something I could work with. Then they could just bend a fitting pipe to the section2.
T
T
You have a header to a flange... to catalytic converter to a flange... to a mid pipe to a flange... to a axle back or rear pipe to a muffler...
Ok, lets try and get on the same page lol
The axle back is the bent pipe immediately connected to the muffler that I just posted of that ebay pic right? That then connects to the section2/midpipe with the resonator in it right?
What is completely split is the pipe immediately connected to the muffler which seems to be the axle back. That particular problem would be solved by just getting the oem muffler on ebay from the link I posted above.
Yeah should be a done deal. Telling me I need a section2/midpipe I didn't see any point. There was a good 4inches+ of pipe still connected of the axle back after the crack to the section2/midpipe that would easily allow me to disconnect the remains of the axle back and bolt up the new muffler/axle back. The crack was like literally right after the muffler where the axle back piping began.
I may play it safe and get new hardware just in case for that particular connection. Which hardware would I need for that? Is there a hardware set I can grab from the dealer or parts store?
Second part, the piece I keep referring to as the Section1. That is the next visible pipe connected to the midpipe that seems to maybe have a slight crack at the weld point. If there is a crack or not and need this replace I will get verified most likely this Saturday. I'm just trying to make sure I'm sourcing the right piece which I feel 100% I am, but....? maybe I'm not?
That part looked exactly like this:
http://www.autozone.com/autozone/par...51_0_3143_5501
http://www.hondaautomotiveparts.com/...5=EXHAUST+PIPE
Spot on, yes aka downpipe. I guess I'm just used to the terminology used when breaking down pipe sections for my other car.
They wanted 500$ for that piece alone. The only thing that was priced accordingly was the muffler at 65$
Between the 4 hondas I've owned... I've never paid more than 200 for an exhaust while supplying the muffler. They typically rape you on the muffler alone... I used a es tuning on my 4dr now for 60 bucks because they said a stock was 186.99...
That LX header/cat is ridiculous as well as very restrictive/ugly
Switch to the EX exhaust system:
Header-->Downpipe-->Catalytic Converter-->Midpipe-->Muffler
All that together, plus the conversion harness to lenthgen your O2 sensor wires to their new locations further down the pipe shouldn't cost you that terribly much.
Plus if you use flanged piping, you don't have to pay a shop the labor to weld it because you can do it yourself in your garage/driveway.
Header/downpipes---http://www.ebay.com/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=99+ civic+header&_sacat=See-All-Categories
Catalytic converters---http://www.ebay.com/sch/i.html?_trkparms=65%253A12%257C66%253A2%257C39%253 A1%257C72%253A5212&rt=nc&_nkw=99+civic+catalytic+c onverter&_dmpt=Motors_Car_Truck_Parts_Accessories& _sticky=1&_trksid=p3286.c0.m14&_sop=15&_sc=1
Catback (midpipe + muffler)---http://www.ebay.com/sch/i.html?_trkparms=65%253A15%257C66%253A2%257C39%253 A1&rt=nc&_nkw=99+civic+catback&_dmpt=Motors_Car_Tr uck_Parts_Accessories&_sticky=1&_trksid=p3286.c0.m 14&_sop=12&_sc=1
Take your pick dude
(and don't rib me on ebay listings-I'm lazy atm)
XD
Take your pick dude
XD
I'm not looking to go crazy Texas, she is my daily and I have my other baby to rip around. I know to well about cats built into the headers being restrictive. My other car is an 04 m3 and in the us for emissions, or just to be stupid, they did the same thing. 4 hour job tool me and a friend putting in new headers to free her up. One of the best mods you could do to that car. Dyno sheets read +20bhp just off of that alone
Looks like ill need a new rubber hangar, gasket and 2 bolts with springs for them. Don't have the pic in front of me right now, may be another piece or two I need.
Ok so replace the two broken parts and call it a day. From what you have described, the mid pipe is fine. You have already discovered for yourself that the shop was way too expensive. No one on this site will tell you to pay a shop anything. It's a DIY site so go do it yourself.
