Another Sidemarker Question - 3-4 minute delay in parking, cluster, and tail lights
Ok so im not new to the sidemarker install.I've done it many times with an EK and only once with an EG.Well i installed the EK9 sidemarkers in my EG casue i liked how big they were.No problem.Wired m up now i have a 3-4 minute delay in my parking lights,cluster lights and taillights.Ive put bigger fuses in those spots and even the radio spot to see if i could isolate the issue to a certain spot.I've come up with no luck just seeing if anyone else has run into this problem before? its a two wire sidemarker.I now have it hooked up to ground and the red/black wire on my corner lights.Any help is appriciated.
Re: Another Sidemarker Question - 3-4 minute delay in parking, cluster, and tail ligh
Basically i have a two wire sidemarker.I have a white and a black wire coming from the lamp.White i think would be positive which is now plugged into the green wire on the corner light.The black one which i think is ground goes to the black wire on the corner thats how i have it now.I put a bigger fuse in those spots so it would handle it.Ive seen them blow because it wasn't big enough.I went up i think 5/10 more than what was in there.
bump
bump
The turn signal power wires are Grn/Yel or Grn/Red whereas the parking light power wires are Red/Blk.
Always install only the proper sized fuse because otherwise you risk a dangerous fire and burned up wires.
i do.All the DIY say that is how they have it setup.is there another way of doing? i searched and that's all i could come up with is those wirring diagrams.
jdmej814
Lighting
01-30-2008 02:07 PM
silentdeath12886
07-10-2007 01:07 PM
Steven.
10-07-2006 01:04 PM
