Where does this sensor go?! 98 Civic DX
Sorry for the repost, I wasn't specific enough. I have a 98 Civic DX with a D16y7 in it. I did a head gasket on and now I need to throw it back together but for some reason I can't figure out where this plug goes....
It's coming off the harness that runs behind the block, under the intake mani. Looks like the coolant temp sensor but it's not.... Please help
Re: Where does this sensor go?! 98 Civic DX
What color are the wires? Hondas have various sensors that fit hat plug. Could be iacv or iat or egr. Make sure not to mix them up. Does the car throw any codes?
It's not starting and I'm hoping its bc this plug is missing, lol. I'll check wire colors and update later tonight. Thanks.
if its a little long it should be the power steering one , when i did my b16 swap onto my cx i had the same plug extra , i dunno what harness are you using i used the Si one and i had that plug as extra
Ok, it seems that one wire is black with either silver or white and the other is green. Its a 2-wire. Any suggestions?
Check your mechanical timing. Did you have a vavle job done while the head was off? If so did you adjust the valves?
Yeah, the shop did it all. Timing seems to be on point. Makes full rotation. I'll check for codes...
bassysingh
10-03-2011 04:58 PM
user 72830283
13
09-18-2005 12:20 PM
