1994 Civic DX Map sensor mixup...
I bought a 1994 Civic DX with a d15b7 in it. It seems to be missing the MAP sensor completely and is throwing codes for MAP errors. The problem is that I don't have a throttle body that allows the MAP to be mounted on it, so I'm assuming it should be a firewall mounted MAP. But I was told that the car shouldn't be taking the firewall map, it should be using the TB mounted Map. I don't know whether to buy a new TB or if a firewall map would work fine. If you guys could give me some insight it'd help a lot.
Re: 1994 Civic DX Map sensor mixup...
ether or should work fine, just make sure that you get the right odb, the computer wont know the difference as long as it can messure manifold pressure
Seagull Management
Someone used a '92 - '93 throttle body. You can either swap the throttle body or use a firewall mounted map like the guy above me said, they both work the same.
Thanks for the quick replies.
shraz
12
07-31-2006 08:39 PM
