Thinking about getting the timing belt done
96 civic EX
I am thinking about getting the timing belt done.
Is there a cam seal around that area that needs to be checked for leaks, if so where?
Does it also have a crank seal, if so where is it?
Re: Thinking about getting the timing belt done
Cam seals should be where cam gear is. Under the part where the screwdriver is pointing.
Front Main Seal: Behind the crankshaft sprocket after you take off the underdrive pulley.
Rear Main Seal: Behind the flywheel. Requires taking removal of transmission, clutch and flywheel.
Here is a guide.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-d16y8-rear-main-seal-2584570/
Here is a guide.
scoob8000
12-19-2011 11:57 AM
Swansen
15
04-01-2009 02:39 PM
