Looking for a parts list B18 LS into 97 CIVIC EK help
So im purchasing a full swap from jdmenginezone i want to know is there any thing else that i need after i get the swap from the enginezone
i know i need shiftlinkage for b series and bseries motor and trans mounts any thing else thanks
Re: Looking for a parts list B18 LS into 97 CIVIC EK help
si rear t bracket and bracket by timing belt. b series axles. its plug and play 90% if you have a ex
literally just did this swap. today is my first day running around with it!
some of the problems i ran into was radiator hoses they are a little different you'll need some ones from an integra and power steering(if your keeping it) you'll need a b-series p/s pump
.. i know when i swapped a b18 in a ef we swapped the whole front spindle to the upper a arm all in one piece from a donor car. maybe not a necessity but could benefit with larger rotors and brakes if its not a ex.
I swapped my ls b18b into my 92 hatch i know it is a little different.My point is i just got the shift linkage from Hasport even know i had my oem for about$150.I was too lazy to refinished the one from my integra.About the radiator hoses my were different as well having a larger diameter ports on the b18.For a could of weeks until i installed my 3 row koyo i rigged it with plastic pipe reducers from the hardware store.Hope this helps a little.Peace
For these car's they're actually the same, for exception of the brakes.
ECU! B series throttle cable!
If the swap is OBD1 you will need to do a 3 wire IACV to 2 wire conversion
no you can get the power steering bracket of a crv google part number or a 99-00 si with b16
prego698
Mid-Atlantic (Sales)
04-29-2011 11:13 AM
Adrian G. Aka JDMonkey
09-05-2007 11:00 PM
