compression check what is pin 2 and 8 connectors to remove?
hi i was wondering what to remove when compression checking,
Chilton manual says distributor connectors pin 2 and pin 8/ what connectors is that?
and for the fuel is there a fuel pump fuse/ i cant find or can i just remove the fuel pump relay?
thanks
thanks
Re: compression check what is pin 2 and 8 connectors to remove?
Well, you can do it one of two ways. Pull the fuse for the fuel pump/relay, or press the gas pedal all the way down, and it puts the injectors in what they call 'clear flood' mode.
o kay thanks i now have a problem the compression tester socket is tuck in the spark plug hole.
BBuncky2
09-02-2008 05:13 AM
spettinger
23
12-05-2002 02:02 PM
