wierd noise after transmisson change :(
so i changed my ls trans with another ls trans and now when i let the clutch out in neutral or any gear it makes a crazy noise.....also i dont have any gears
plz help
plz help
Re: wierd noise after transmisson change :(
clutch installed backwards? input shaft bearing shot? input shaft damaged? axles seated properly? theres too many things that could be wrong here, could you post a video?
Sounds like clutch release bearing slid off of clutch release fork. Did you reuse all your old components, meaning just trans replacement, or did you use replacement trans clutch release fork, clutch release bearing, pressure plate, clutch disc, etc?
he says he doesnt have any gears, so i would think its not the release bearing, only because he would not be able to get into gear because the fork is not able to release the clutch by itself.
i was told it was a good trans and i reused my clutch, release bearing, and fork from my old trans that worked fine.
ty for the responses
SO I CHANGED THE TRAMSMISSION BAD TO THE OLD ONE AND NOW IT WONT GO INTO ANY GEAR BUT IT DOESNT MAKE ANY WIERD NOISES
The problem your having now is exactly the problem I had a year ago, would go into all gears with vehicle off, start car and depress clutch pedal, wont go into any gear. I tried everything, hydraulics, Genuine honda MTF, new clutch fork, in the end it ended up being a bad pressure plate, which was brand new from NAPA, got a Genuine Honda pressure plate, problem solved.
k also some more info when i put the key in the ignition now and put it to the on position and let the fuel pump prime....the speedo needle jumps to about 40 mph and falls back down??? ive never seen that happen before but idk
ty for any help
ty for any help
well i got the trans working again my dumb *** didn't put the drive shaft in all the way
now to fix the cel
now to fix the cel
ok now the car seems to be ok but i still have the speedo woerd needle jumping issue....any ideas?
New to ht but I have the same issue with my speedo. It's time for a new one mine starts to work after about 20 mph then when I go up to 80 it gets stuck and the thing is way off
Solstic
06-13-2012 11:34 AM
