replacing the transmission and clutch tomorrow...d16
Old 09-30-2011, 06:21 PM
97accordbuildlx's Avatar
Default replacing the transmission and clutch tomorrow...d16
what are all the fluids ill need to swap in the new transmission? d16z6 setup with s20(si) tranny.
Old 09-30-2011, 06:37 PM
fonkernuckle's Avatar
Default Re: replacing the transmission and clutch tomorrow...d16
At least 2 quarts of 10w30 motor oil or oem honda manual trans fluid,some grease to grease up the input shaft/throw-out bearing and some beer.
Old 09-30-2011, 06:45 PM
hahahaha yea man for sure. ive been rockin a stock slipping clutch and a poppy/grindy second and third gear for a while now, cant wait to get on it a little bit after i break the clutch in
but yea thanks i was just makin sure i had the right oil
Old 09-30-2011, 07:07 PM
canadaek's Avatar
honda mtf i'v used regular oil and blown many trannys not sure if it had anything to do with it but now i only use honda mtf. some brake clean to clean the flywheel and other parts
Old 09-30-2011, 07:43 PM
yea i kinda read into it heres heres a link http://answers.yahoo.com/question/in...2194347AAK162b .
iduno ive never changed a tranny before my friends helping me so im just trying to get everything well need for tomorrow,
Old 09-30-2011, 08:05 PM
Linked's Avatar
i used to put n honda mtf in my eg tranny.
i can't remember but i think it was 94EG8 who said honda mtf was only for 96-00 d16 transes, pre 6th gen civics were built to have 10w-30 in them
Old 09-30-2011, 08:59 PM
nur53_401k's Avatar
i use enos trans oil just saying but all you need is 2 jacks a friend with a strong back and time i did my tranny swap in 5 hours with one air tool in the dark on the ground
Old 09-30-2011, 09:09 PM
VXvtec's Avatar
10w30 because it will last longer and won't burn as fast as 5w30.
dominique91
10-25-2017 05:55 AM
da_33
03-26-2007 06:34 PM
vinnye89
08-23-2004 11:52 PM
AirWaveGT
06-27-2004 07:55 PM
crown14
04-11-2004 09:14 PM
Quick Reply: replacing the transmission and clutch tomorrow...d16
