CEL i get a 6 and 7 quick short blinks reapingtly!! HELLLPP
Got a check engine light
I put a paper clip on the thing to get the code
and it strarts flashing 6 quick blinks
then stops blinking for a second
and then 7 quick blinks all of a sudden
stops for a second then 6 blinks
stops for a sec
then 7 quick blinks
again and again
6 quick blinks then a 7 quick blinks
and on and on it does this
WHAT SHOULD I DO?
help me out dont know wut this is all about???
pls
[Modified by infamousek, 8:28 PM 9/18/2002]
stops for a sec
then 7 quick blinks
again and again
WHAT SHOULD I DO?
pls
Re: CEL i get a 6 and 7 quick short blinks reapingtly!! HELLLPP (infamousek)
OBD-II ONLY (1996-Present)
67 Catalyst System Efficiency System below threshold, defective catalytic converter
Re: CEL i get a 6 and 7 quick short blinks reapingtly!! HELLLPP (WR93EG)
If its quick blinks for each, its codes 6 AND 7. 6 is 6 Engine Coolant Temp Circuit- Reading too low, high, short or open, bad ECT.
7 is Throttle Position Circuit Reading too high, low, short or open, bad TPS
Did you put an intake or throttle body on recently? Could be they are unplugged or something. I would take a look.
http://www.hondata.com/techecucodes.html
BTW, it's 2 codes. Code 6 and Code 7.
[Modified by Spade, 2:43 PM 9/18/2002]
smithbling
11-19-2002 12:26 PM
