HELP: Rear disc. conversion
I have already search and read most the the sites on how to do the conversion. My question is, what do I with the anti-lock brake line. I am doing the conversion on a 93 HB. I haven't read anything about that on any of the sites on "how to."
Do i just cut and trash that line or what?
Re: HELP: Rear disc. conversion (skunk2unerz)
take it off. if you follow the line around you will notice it is held in place by a 10mm bolt. take it out. the chase the line back to this little rectangle box. it has 2 10mm bolts on it. remove them. then remove the bolt inside that holds the pick up in place. all of 5 mins work. easy as cake
Re: HELP: Rear disc. conversion (snail)
so I dont need the wiring. I knew how to take it off, but wasnt sure if it was to be used with the conversion. Thanks....i will take it off 2moorw..
d16vteceg
12-02-2005 01:11 PM
BlueIntegraBoy
13
07-26-2005 08:01 PM
