best master cyl and booster for 97cx w/gsr 4disc swap?
I have a 97 CX with junk-yard gsr brakes on it.. What would be the best/easiest master cylinder and booster to upgrade to?
Re: best master cyl and booster for 97cx w/gsr 4disc swap? (LShbVTEC)
alot lot of pples us the integra RS m/s since it didint come with abs... give b18c5-eh2 a IM..... he done it ... or do a search if you can............
Get the 1" GSR MC & Booster and take the Integra RS PV (part #4040 stamped on it)
simple as that..
simple as that..
Use the 98-01 integra MC and booster, it bolts right up to 96-00 civics. If you want a 40/40 prop valve, get the 99-00 si prop valve.
Re: best master cyl and booster for 97cx w/gsr 4disc swap? (Jackson)
The si prop valve does not have the extra inlet for the abs line and is made for the 96-00 civics. The integra mc will go right in whether it had abs or not. I am using the 98+ gsr mc on my 2000 civic with no problems at all. I did not bend any lines or reflare anything.
if you moved the abs unit from the gsr you would have moved a whole lot of stuff. including sensors, axles, abs releys, as well as a lot of other stuff. If you already had abs...umm i dunno how well your abs will work if you upgrade your booster and stuff. Theoretically it should be fine but i don't have an answer for you. Yeah do use the 40/40 proprotionaling valve if you plan not to use ABS otherwise your brake balance will be alll screwd up.
Re: best master cyl and booster for 97cx w/gsr 4disc swap? (visi0n)
how much did you pay for you MC, Booster, and Prop valve
honda says 114 for the prop valve here in daytona
I'm in a similar situation.
I have a 93 DX hatch and I recently purchased a complete GSR brake swap. Since my car doesn't have ABS, should I find MC from a RS?
I paid $35 Canadian for mine from a scrap yard..it came off a 94 'Tegra RS.
and $125 Canadian for a 2001 GSR MC and booster.. I got it all installed last week. It works great with the new Fastbrakes kit.
Re: best master cyl and booster for 97cx w/gsr 4disc swap? (Kev95lx)
You might want to have them double check the part number between your CX and SI. They should be the same for the proportioning valve. I know they are the same between the 99+ DX and SI
Re: best master cyl and booster for 97cx w/gsr 4disc swap? (elmo)
it's actually really simple, just make sure you have a PV stamped with a 4040 on it and 6 brake line entry points. That'll signify a NON-ABS Rear disk PV.
95civic_ls_vtec
06-16-2010 02:13 PM
Another Drew
07-04-2005 06:35 PM
