CEL....ECU related
CEL....ECU related
Hey whats up guys..my ECU just came in..its a 2001 LS ECU..and yes i know it has an immobilizer....but i have that covered...i unplugged my EX ecu and plugged up the integra ECU...i was just checking to see if everything plugged up ok..sure enough everything plugged up..i turned the ignition to see if the immobilizer was doing its job..and sure enough it did.....soo i replugged the old EX ecu back up...turned the car on.....but now i have a CEL...why did that come up..and is it safe to drive the car?
Khoi
[Modified by Sohc Driver, 9:40 PM 2/18/2003]
Khoi
Re: CEL....ECU related (Sohc Driver)
you will need to know the code it is throwing to determine whether it's a hard code (throwing the ecu into safe mode) or a soft code.
Re: CEL....ECU related (poison)
if it was a hard CEL..resetting the battery wouldn't have fixed the problem would it?? so any ideas as to why the CEL came on with what i did?
Khoi
Khoi
if you reset the ecu, and the light does not come on, it's most likely not a hard code.
a hard code will throw the ecu into safe mode because the ecu thinks that whatever sensor/solenoid is not working may cause the engine to blow/cease.
a soft code will not affect much on the motor from allowing to run properly, and in resetting the ecu, and not throwing cel, it was most likely a soft code that you will not need to worry about; unless, of course, if it pops back up.
unfortunately, i have no idea of as to what the code you were throwing.
oh yeah..i failed to mention..that i had the key in the ignition..when i replugged my old ECU back up...did that have anything to do with it?
Khoi
Khoi
but i meant..i had the key in..while i was replugging the old ECU.......know what i mean..the igntion was on....while i was doing it...maybe when i was pluggin in the ECU..it freaked out....noticing that a plug was missing..because when i plugged in the 2nd plug..everything electronic turned on...im thinking..the ECU freaked out...
Khoi
[Modified by Sohc Driver, 10:44 PM 2/18/2003]
Khoi
ef_you_again
03-17-2005 11:14 PM
