window cement or motor mount inserts?
Old 02-16-2003, 09:08 PM
B_1_8_hatch's Avatar
Default window cement or motor mount inserts?
okay, i've heard some people on here talk about putting window cement where the motor mounts go to make a solid mount.
so is window cement good to use, or should i just buy the prothane motor mount insert kit?
93hb
Old 02-16-2003, 09:43 PM
EK MONEY's Avatar
Default Re: window cement or motor mount inserts? (93hb)
use inserts. If you dont use inserts use and old tire. Cit it into strips and jam it in
Old 02-16-2003, 10:34 PM
confidence's Avatar
Default Re: window cement or motor mount inserts? (Peagreenhatch)
its just polyurithane they are injuceting into the mounts. you cap one side with a piece of carboard and then fill up the gaps around the rubber with the poly. it is cheap and it works. the benifit of getting the inserts is that you can take them out if you don't like the vibration or if you want to sell the car. useing pieces of tires is a new one to me....
Old 02-16-2003, 10:36 PM
JV
Who?
JV's Avatar
Here's alittle info on the homemade mounts...
http://importnut.net/motormount.htm
http://www.mr2sc.com/websites/tech/SolidMounts1.htm
Old 02-16-2003, 11:01 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: window cement or motor mount inserts? (JV)
that first link is great!! I'll be doing that
Old 02-17-2003, 05:12 AM
qcoffey's Avatar
Default Re: window cement or motor mount inserts? (Emerica)
If your car is your only car and daily driver, then I would reccommend getting the inserts. I like the homegrown style but being without the ride for 24-48 hours just isn't feasible.
Old 02-17-2003, 05:14 AM
stevel's Avatar
Default Re: window cement or motor mount inserts? (qcoffey)
i glue the inserts into the mounts with window cement. Doesn't move!!
s
Old 02-17-2003, 06:50 AM
euclid's Avatar
me too.... you know if spoon or mugen marketed a bottle of polyurethan motor mount filler everybody would be on top of it. i was planning on doing inserts anyway and these seem just as good, without having to ziptie the e.s. inserts in
cpthaegdon
26
06-02-2011 02:49 PM
nick91civicsi
04-06-2008 07:59 PM
kcirdnek
10-06-2004 10:29 AM
Briman2021
01-31-2003 09:17 PM
W.O.T.
08-28-2002 01:52 AM
Quick Reply: window cement or motor mount inserts?
