What proportioning valve is this???
Which proportioning valve is this???
There are 6 holes for lines to connect, letters on it are "F9CE" "OD4" and "89Z"
I got this off from a 99 0r 00 si at a yard, but from closely looking at the rear brake, i think the car was stolen before ending up in the yard. And looking at the rear brake, it is NOT rear disc, is Drum. So i think the peeps must have swapped the rear disc, but i am not sure if they swapped the proportioning valve too.
[Modified by intezn, 8:37 PM 2/18/2003]
[Modified by intezn, 8:46 PM 2/18/2003]
Re: What proportioning valve is this??? (intezn)
edit: there is nothing on it that says, 40/40, 30/30, 30/40 or what ever on it.
Re: Which proportioning valve is this??? (intezn)
I believe it's from a GSR ...6 valves is usually for a ABS system car.
[Modified by Kev95lx, 3:02 PM 2/19/2003]
Re: What proportioning valve is this??? (piscorpio)
I could take a look at my EX, but I would have to put on my coat, run outside in the cold, pop my hood, and look for the #'s.....it is just a little to early for that, but I will remember to check later if you still need my help by then.
Re: Which proportioning valve is this??? (Kev95lx)
[Modified by Kev95lx, 2:57 PM 2/19/2003]
Re: Which proportioning valve is this??? (piscorpio)
i thought the abs valves had 4. 2 for the lines coming from the MC, and then 2 going to that ABS resevoir.
I dunno... I could be wrong on this...
I always thought the porpotionate valve to get would have to have 6 holes. I have a porportionate valve from a gsr with abs, and it's 4 holes.
Re: Which proportioning valve is this??? (Chris N)
Just checked my EX valve, and it is stamped C23CL. It also has 6 valves and is not ABS. Don't know if that helps any, sorry.
There are 6 holes because 2 lines come from the master cylinder and then 1 more hole for each corner. The ABS have 4 last I checked.
[Modified by Slurp56, 7:40 PM 2/19/2003]
That looks exactly like the p valve that I took out of a 98 LS or GSR from the junkyard. Useless if you plan to use it in a brake swap w/out abs.
I actually made a post about this but I guess it didn't get archived.
[Modified by CXHatchback, 9:42 PM 2/19/2003]
Jonathan_ED3
03-24-2004 02:50 PM
1992, 3030, 3040, 4040, a15ce, abs, accord, del, honda, portioning, proportion, proportional, proportioning, sol, valve
