how do i start up a engine to see if it good or not
im planning to buy a swap and i want to start up the engine to see if it works
what do i have to do to start it
Re: how do i start up a engine to see if it good or not (intezn)
have the Gas line hooked up to the fuel filter (pressure issue might come up) then hook up the battery, buy a remote start siwtch from Summit or some one.
Have not tried it on a Honda but worked with 383s & 350s
Re: how do i start up a engine to see if it good or not (ace1875)
Re: how do i start up a engine to see if it good or not (Briman2021)
you need the ecu, electrronics, etc to do this. Did it on a 305, but whole different story. You better have it on an engine stand or something too because it will go out of control when it fires up.
Re: how do i start up a engine to see if it good or not (Rtzx9r)
preasure check it, that be bad *** if you tried to start it outside the car... all you need to do is give power to the started and you can have it make compression, that will tell you about your seals, valves, and so forth. there is also a tool that runs straight compression into the cylinders and if the preasure drops then something is leaking... Same idea, but you dont have to start the motor..
H-T Poker champion
Re: how do i start up a engine to see if it good or not (Dominican_Kid)
just put it in your car.. it will take all of 5 hours before you can start it up..
Kevin Levin
Honda Civic (2016 - Current)
06-02-2019 08:57 PM
acuraTboo
Honda Civic (2006 - 2015)
04-24-2013 04:16 AM
