JG Throttle Body / Skunk Cams question...
Old 02-16-2003, 11:34 PM
skafia's Avatar
Default JG Throttle Body / Skunk Cams question...
Okay. My friend has a JDM B16 SiRII motor and he is planning on getting Skunk Stage 1 Cams and he's wondering if the JG Throttle Body (is it 65 or 70mm?) is worth it over the ITR throttle body. What would be better to use?
Also, I know it isn't required to get aftermarket camgears with cams, but is it necessary to get the most power out of the cams? Thanks.
Old 02-17-2003, 09:21 AM
skafia's Avatar
Default Re: JG Throttle Body / Skunk Cams question... (skafia)
Bump.
Old 02-17-2003, 09:26 AM
tek_civic's Avatar
getting the gears will help to fine tune the power curve so you can have it more where you want it. and don't go too large on the TB or you will actually decrease performance.
Old 02-18-2003, 09:31 AM
skafia's Avatar
Default Re: JG Throttle Body / Skunk Cams question... (tek_civic)
Nobody hangs out here. Only 1 response? LOL.
Old 02-18-2003, 12:04 PM
joe_bocc's Avatar
cam gears are almost a must when you upgrade your cam. Tuning with them can make a world of difference.
As for the throttle body; since your friend is only getting the stage 1 cams, the 65 mm might be better suited. kind of like getting the ITR throttle body, just a little bigger.
whatVTEC
10-30-2006 05:38 PM
caminSi
12-07-2005 03:22 PM
knowledg321
17
09-05-2005 08:36 PM
the g2 teg
09-03-2005 03:09 PM
AussieK24
07-30-2002 06:41 PM
Quick Reply: JG Throttle Body / Skunk Cams question...
