knock sensor wire color on 95 teg harness
likeok guys, d15's out, b18c's in. I swear it looks like this gsr 4 door full exhaust will boolt up so I think im going to try it.
but my main concern is:
knock sensor wire. Im to dirty and in need for this nfo to search.. I just need a quick answer.. plz..
ok, on the gsr motor harness, what color(s) is the knock sensor wire that connects to the civic harness at the firewall? I plan on tapping there then manually wiring it to the ecu. I believe I know where it goes on the computer. I looked at someone elses and they had it going to the second pin on the top of the very right clip.. thx
thanks.
92 cx 95 gsr motor / harness
thanks.
Re: knock sensor wire color on 95 teg harness (Steve Berman)
I believe the wire is blue/black.
The knock sensor is mounted at the rear of the engine near the cylinder head.
good luck.
good luck.
Re: knock sensor wire color on 95 teg harness (poison)
actually the knock wire is a red with a blue stripe.
i just had a look... and the only one that weas behind the head... and wasnt at the civic harness. was solid red with baby blue wire..
there's only 2 sensors on most of the back of the blocks, and thats the oil idiot light sensor which has one wire, and the knock sensor. The knock sensor is right next to the head
Hope you got it solved man. Last time i checked it was Red/Blue but I was referring to another manual and must have got it switched heh.
Re: knock sensor wire color on 95 teg harness (streetdreams02)
it was red with blue line for future reference. No need to reply. Thx to all that assisted me. Car is running great. I will post a sum up of everything soon.
MarkCayabyab
11-15-2013 07:53 AM
MassScene
01-03-2005 12:56 PM
