need help installing ingalls camber kit
its a new kit,going into a 95 civic,im guessing its the 1-3 degree adjustable kind.i got them in there easlily,but what i was wondering,there is a ring around the base of the bolt that goes into the body,should i remove this ring.its kinda like a spacer,i would think that it should fit up into the hole.but it does not fit up into the hole.So with it one there the camber peice does not sit flush,it sits on the ring.its kinda hard to explain if you have never installed one.if i remove the ring the whole piece would sit flush up into it.it just does not look right sitting on the ring.
Re: need help installing ingalls camber kit (civictypenos)
i have the ingalls kit on my car...i dont think the alignment shop used the ring on the kit...i think they just replace the old camber assemble and should fit like stock..good luck to ya.
itsJDMyo
13
01-07-2005 10:40 AM
