Check Engine Light Code 14
So I pulled the codes and it looks like 14 (maybe 13) where are these located at?
13 BARO Sensor (Atmospheric Pressure) defective circuit or unplugged /
defective sensor
14 IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
I have a helms manual but I am at work. CEL comes on when I start the car and it is cold, light goes away if car is turned off and turned back on after running for a few.
defective sensor
Re: Check Engine Light Code 14 (Solracer)
The BARO Sensor is located inside your ECU. If it goes bad, then its time to replace the ECU, however, if your running an AFC (or something similar), this code seems to pop-up from the installation of this device.
The IACV is located on your throttle body. Its used to pass additional air around the TB blade to sustain an idle. One quick test you can perform is to unplug it when your engine is idling. When you unplug it, the idle should drop.
Since you have a Helms ( ), just flip to the troubleshooting section and follow the steps outlined.
Re: Check Engine Light Code 14 (EE_Chris)
I have noticed that the car has been ideling rougher/lower I pretty sure the code was 14. I don't have and AFC. I recently replaced the radiator hose's and the Thermostat. I wounder if I bumbed the sensor or unpluged it.
DannyITR
07-21-2004 05:10 PM
