b18 direct fit into cx??
does a b18 fit direct into a cx. and what wiring changes do i need to make or what do i need for it to work. thanks
Re: b18 direct fit into cx?? (zc_civic91)
pritty sure it is a direct fit I think also that you can reuse the cx wire harness allso if you use an OBD1 ecu it should plug right in to the stock conector
It's a direct fit. cept for ect... parts like mounts here and there, but you use your civic wirings if your swapping into a Ek, but for others its plug and play. You're goin got have to extend a few wires here and there. But its mostly like Plug and play.
direct fit..i suggest you get a vtec harness since the CX harness has a 1 wire o2 and the b18's are 4 wire.....it will make your wiring a little easier...just have to add wires for vtec sol and vtec pressure, knock, and IAB
diycx
09-13-2003 04:11 PM
