Draining coolant from the block of a B16a3
Old Oct 18, 2003 | 10:48 AM
XxslayerxX's Avatar
Default Draining coolant from the block of a B16a3
Hi im installing my new intake manifold and i was wondering if this is the plug in the block that i loosen to drain my coolant. Here are some pics.
Old Oct 18, 2003 | 10:50 AM
Formula 1's Avatar
Default Re: Draining coolant from the block of a B16a3 (XxslayerxX)
that would be correct just loosen that...i would our so strait water threw the radiator after all the collant has come out...just cleans up lil junk in there and can't hurt
Old Oct 18, 2003 | 10:52 AM
XxslayerxX's Avatar
Ok cool thanks alot!
Old Oct 18, 2003 | 10:55 AM
Formula 1's Avatar
Default Re: (XxslayerxX)
no prob what kinda Im you putting on? y r u draining the coolant ne ways?
Old Oct 18, 2003 | 10:56 AM
EG2 SiR's Avatar
don't be surprised if some sand comes out... I removed mine in the past and that's what happened to me.... I assume it was just there from the original "sand casting" of the block.....
Old Oct 18, 2003 | 11:18 AM
TurBoXBirD16's Avatar
Default Re: (EG2 SiR)
and maybe u want to use some sealant when you put it back in..
coz mine leaks after i put back in
i need to put some sealant(forgot which kind) to put that cap back in, then it's good now
good luck
Old Oct 18, 2003 | 11:30 AM
EG2 SiR's Avatar
Default Re: (TurBoXBirD16)
teflon or "plumbers" tape, is your buddy.
Old Oct 18, 2003 | 11:32 AM
Formula 1's Avatar
i have done about 20 engines like that and had no proobs and couple were older d16s just torque it right and u will be good
Old Oct 18, 2003 | 11:34 AM
XxslayerxX's Avatar
I have a skunk2 IM that im putting on.
Old Oct 18, 2003 | 11:36 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurBoXBirD16 &raquo;</TD></TR><TR><TD CLASS="quote">and maybe u want to use some sealant when you put it back in..
good luck
If you change the crush washer on it, you will have no problem with it leaking.
Old Oct 18, 2003 | 12:42 PM
Formula 1's Avatar
Default Re: (90blackcrx)
skunk2 IM
Old Oct 18, 2003 | 03:29 PM
ED8DX's Avatar
Default Re: (SikCivic)
I removed that plug and sand and rust particles came flowing out. It was the last straw for my cooling problems. I had a fluidyne radiator two electric fans, new coolant and water pump, and clearing out the block crud finally solved the damn overheating probs.
Old Oct 18, 2003 | 03:40 PM
Formula 1's Avatar
Default Re: (ED8DX)
good to do every once in a while along wit changing your oil let a quart run threw it ever once in a while whie changing it and the pan is open..same wit some water threw the block bout .5 gallon good to roll...its comforting once all that stuff is good to go and u know it
Old Oct 18, 2003 | 03:42 PM
EK MONEY's Avatar
for installing the skunk 2 i believe you can just drain the radiator.
Old Oct 18, 2003 | 03:47 PM
Formula 1's Avatar
Default Re: (Peagreenhatch)
might as well flush it tho...doesn't hurt and they u have the comfort of knowing its done
Old Oct 18, 2003 | 03:51 PM
JoshuaVTEC's Avatar
b16a3!?!?
Old Oct 18, 2003 | 03:54 PM
EG2 SiR's Avatar
Default Re: Draining coolant from the block of a B16a3 (JoshuaVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshuaVTEC &raquo;</TD></TR><TR><TD CLASS="quote">b16a3!?!? </TD></TR></TABLE>
what's so odd about that? It's from a del sol
Old Oct 18, 2003 | 03:55 PM
JoshuaVTEC's Avatar
Default Re: Draining coolant from the block of a B16a3 (EG2 SiR)
Ah. I'm a learner
Old Oct 18, 2003 | 04:02 PM
EG2 SiR's Avatar
It's all good... sorry if I sounded like a dick.
Old Oct 18, 2003 | 05:00 PM
JoshuaVTEC's Avatar
No it's cool, I always though the Sol was a B16A1... now I know
Old Oct 18, 2003 | 05:21 PM
EG2 SiR's Avatar
actually, they used the B16A2 and B16A3 through their production life...
Old Oct 18, 2003 | 07:12 PM
tvr.blu.eg6^'s Avatar
my b16a3 doesn't have a coolant bleeder on the block.
not all motors have bleeders. (which surprised me)
weird huh?
Old Oct 18, 2003 | 10:21 PM
Default Re: Draining coolant from the block of a B16a3 (tvr.blu.eg6^)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tvr.blu.eg6^ &raquo;</TD></TR><TR><TD CLASS="quote">my b16a3 doesn't have a coolant bleeder on the block.
weird huh?</TD></TR></TABLE>
Are you talking about the bleeder screw or the coolant drain bolt. I am pretty sure all engines have the bolt, but not of all them have the bleeder screw.
Old Oct 18, 2003 | 11:56 PM
XxslayerxX's Avatar
what is the difference between a b16a2 and a b16a3? I always wondered that. So far i got the IM out and everything swaped on the new one and all the lines are marked. Now i just have to get it on tomorrow and hope i can get the nuts back on and beable to torque them. I was hard to get at the 2 middle bottom nuts to loosen them.
Old Oct 18, 2003 | 11:59 PM
XxslayerxX's Avatar
here are some pics so far...
