those with 99-00 Si's...
what harness does you secondary o2 tie into? is it the main engine harness or is it something in the cabin? pics would be HUGE if you have some. thanks a lot for anyone who can help me out.
Re: those with 99-00 Si's... (2000CX)
it ties into another harness. The engine harness only goes into the engine bay from the ECU. I think the 2ndary O2 sensor harness goes into the green plug harness at the ECU.
Re: those with 99-00 Si's... (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 »</TD></TR><TR><TD CLASS="quote">
anyone second this?
anyone second this?
Mr. Badwrench
doin a jdm or usdm based engine, i am in the midst of a 99 swap and only one o2 is needed, but if you are doin a usdm engine you will need that.
Re: those with 99-00 Si's... (boostedcivicsir)
or if he is staying with OBDII
If id dries up latar tonight i will go look under my car i don't want to get all wet.
Re: those with 99-00 Si's... (99blackcivicSi)
yes...i am staying obdII...and i would love to know where the harness ties into. anyone comment on the 'green plug' theory? from seeing how long the harness on the stock o2 was i assume it has to run up into the cabin right around the driver side floor...but then where is beyond me right now?!?!?!
Actually, I think I'm wrong. I forgot that there is a harness that goes into the car on the driver side. I think that is where the 2ndary O2 wires feed through. But I think they go from under the center console to the driver side to the engine bay to the ecu.
can anyone actually see what harness it ties into and where? i am trying to get an idea so i can make it truly plug and play...hard wiring is not working for me. this is the secondary i am talking about...keep that in mind.
I'm not sure where it comes from, but I know for a fact that it doesn't come of the engine harness. It goes straight into the floorpan for the o2 sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX »</TD></TR><TR><TD CLASS="quote">what harness does you secondary o2 tie into? is it the main engine harness or is it something in the cabin? pics would be HUGE if you have some. thanks a lot for anyone who can help me out.</TD></TR></TABLE>
It runs up directly obove the cat to a plug...That plug goes throught he floorboard to the ecu
Re: those with 99-00 Si's... (nasi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nasi »</TD></TR><TR><TD CLASS="quote">
ok...i got the through the floorboard part. how exactly does it get to the ecu? the o2 itself has a very short harness...so is this something that only comes on the Si? i ripped my whole entire interior out tonight on found nothing that even resembled the plug on the o2.
Re: those with 99-00 Si's... (KURRRWA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KURRRWA »</TD></TR><TR><TD CLASS="quote">
it runs straight to the primary O2 sensor.
JDMInspired
Honda Civic (2001 - 2005)
03-10-2008 06:30 PM
