Which one Skunk2 or Ingalls camber kit?
I have bad camber its off a tad and I need a kit just wondering what you guys have to say some experiences likes and dislikes. My car isnt dropped yet its still riding on factory suspension.
be professional
Re: Which one Skunk2 or Ingalls camber kit? (BADGUYNY)
You don't need an adjustable camber kit with stock suspension.
If you're having tire wear problems, go to an alignment shop and have them set your toe to zero.
Re: Which one Skunk2 or Ingalls camber kit? (Targa250R)
Here is a link to the other post about the camber problems
https://honda-tech.com/zerothread?id=652697
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADGUYNY »</TD></TR><TR><TD CLASS="quote">Front Left: camber -0.3 caster 0.5 Toe -5.07 Front Right camber -2.0 caster -0.8 toe 2.79</TD></TR></TABLE>
That's your problem right there, just as I suspected. Your toe is killing your tires. A camber kit will not help prevent your tire wear.
Go back to the alignment shop and tell them to forget camber and caster - just set the toe to 0. You shouldn't have any problems with tire wear after that.
CAMBER IS WAY OFF!!!!!!! which camber kit well fix this ???????????? BEST CAMBER KIT OUT THERE??????
Kangolbrand
Suspension & Brakes
17
03-30-2006 02:15 PM
