Edelbrock Turbo Kit for The d16y8 opinions
Old 10-17-2003, 11:27 AM
4doorex's Avatar
Default Edelbrock Turbo Kit for The d16y8 opinions
Anyone installed one yet? I have seen the ads and read the how to install articles. I am impressed with the amount of parts you get in the kit; FMIC, New intake manifold with 4 extra injectors, etc. Has anyone installed one yet and run it at the track? I am curious to see quarter mile numbers and trap speeds.
Matt
Old 10-17-2003, 11:36 AM
Apex i ITR's Avatar
Location: Toronto, Canada currently residing in ATL, GA, USA
Default Re: Edelbrock Turbo Kit for The d16y8 opinions (4doorex)
Setup basically like a Greddy kit with IC option and just as expensive if not a little more.
Old 10-17-2003, 11:51 AM
The Internet Tough Guy's Avatar
Default Re: Edelbrock Turbo Kit for The d16y8 opinions (Apex i ITR)
ask marauder he has it and loves it. also search this has been talked about before. http://www.turbod16.com is a good place to look also
Old 10-17-2003, 11:53 AM
CaTiRo's Avatar
you get more than greddy, you get a nice spearco intercooler, performer x manifold w/secondary fuel rail & four additional injectors. and isn't the garrett t28 better than the greddy turbo? but then again this kit is price around $3500 whereas the greddy kit is much cheaper.
Old 10-17-2003, 12:26 PM
kommon_sense's Avatar
Default Re: Edelbrock Turbo Kit for The d16y8 opinions (CaTiRo)
edelbrock is a *COMPLETE* kit. After you add the additional necessary parts to the greddy (intercooler, fuel management, bov, etc.), it will be nearly the same price as the edelbrock. Edelbrock also comes with a ball-bearing turbo. You can find the edelbrock kit for around $3100. Still expensive, but probably the best d-series kit on the market.
Old 10-17-2003, 01:45 PM
Navid OG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex i ITR &raquo;</TD></TR><TR><TD CLASS="quote">Setup basically like a Greddy kit with IC option and just as expensive if not a little more.</TD></TR></TABLE>
Old 10-17-2003, 01:48 PM
pdiggitydogg's Avatar
harder to turn up the boost than greddy's...but its a hell of a lot nicer setup
Old 10-17-2003, 01:49 PM
Spade's Avatar
Wrong.
Larger turbo, better designed exhaust manifold, intercooler, aluminum piping, Tial BOV, 7 psi, and fuel management, intake manifold with additional injectors and fuel rail.
Old 10-17-2003, 02:25 PM
Daniel's Avatar
Default Re: Edelbrock Turbo Kit for The d16y8 opinions (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">ask marauder he has it and loves it. also search this has been talked about before. http://www.turbod16.com is a good place to look also</TD></TR></TABLE>
170 whp, I believe are his numbers. VERY IMPRESSIVE. Most of the GReddy SOHC Civics I see at stock boost make 170 crank hp. If I had the funding, I'd rebuild my engine and use the Edelbrock kit. Much better fuel setup than GReddy (although I've heard their new kits use e-Manage now instead of the blue box). Edelbrock supposedly dyno tuned their fuel setup specifically for the P2P computer, so everything bolts on and should work on maximum power. No extra tuning necessary.
Old 10-17-2003, 02:26 PM
Spade's Avatar
Default Re: Edelbrock Turbo Kit for The d16y8 opinions (Daniel)
178 whp actually.
Old 10-17-2003, 02:35 PM
Marauder's Avatar
Default Re: Edelbrock Turbo Kit for The d16y8 opinions (Spade)
Here's my dyno with the Edelbrock D16Y8 kit on a SuperFlow eddie current dyno. When it was dyno'd on a DynoJet it made the 178 whp and 148 ft-lbs. Just different dynos result different numbers Its also a Garrett GT28 turbo, not the old T series.
Old 10-17-2003, 03:01 PM
Daniel's Avatar
Default Re: Edelbrock Turbo Kit for The d16y8 opinions (Marauder)
Marauder, have you smogged your car yet? If so, what were the results? Because the Edelbrock is 50-state, right? I knew a lot of GReddy guys who were failing CA sniffer on their Z6 at 5 psi of boost and stock cat.
Old 10-17-2003, 03:03 PM
Marauder's Avatar
Nope....Don't think I have to until 2005.
Supposively the Edelbrock test car passed the strict smog test fairly easy. I just had a new cat put in my car before the turbo (back in March) so I should be good for a smog test. Yes, my Edelbrock turbo kit has a E.O. number
The Greddy fuel system is pretty crude. In the stock fuel trim from Edelbrock, if you don't screw with anything, you should be fine. I have a friend who works for a Honda repair shop, he just picked up the kit for his '99 EX, but is converted to the OBD1 computer. I should check whether his shop has smog equipment and maybe have him check his car on it when he's done installing it.
Old 10-17-2003, 04:20 PM
zseeanz's Avatar
badass kit if you have the money. I did, so I ordered one
gentek1145
08-05-2010 06:55 AM
slow_redcivic
04-30-2006 04:04 PM
dubrand
12-03-2004 06:09 PM
93solsigsr
04-09-2003 04:34 PM
AllMotorITR
08-05-2002 04:51 AM
Quick Reply: Edelbrock Turbo Kit for The d16y8 opinions
