What do I need to change the Front LCAs?
Hey guys.
I have a stock 92-95 civic front sway bar laying around in my garage.
I have a 92 Civic VX - Is there anything else I need other than Front lower control arms so that I can fit the front sway bar on?
...and do you guys know how much front lower control arms (with the hole for the sway bar) goes for? I can use Integra (all models) and/or 92-95 civic ex/si front LCAs, right? thanx.
Re: What do I need to change the Front LCAs? (Heinz57)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heinz57 »</TD></TR><TR><TD CLASS="quote">I have a 92 Civic VX - Is there anything else I need other than Front lower control arms so that I can fit the front sway bar on?</TD></TR></TABLE>
You'll need the mounting brakets on each side, they mighta came with the swaywhen you picked it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">...and do you guys know how much front lower control arms (with the hole for the sway bar) goes for? I can use Integra (all models) and/or 92-95 civic ex/si front LCAs, right? thanx.</TD></TR></TABLE>
I paid like 25 for one side when I replaced mine due to my little curb accident. Yes, all integra models and 92-95 ex/si fit.
Good Luck
Good Luck
Re: What do I need to change the Front LCAs? (Echo7847)
hey echo..thanx for the reply.
by mounting brakets, are you talkin' about the endlinks (if its called the same thing as with a rear sway bar)?...i was thinking i'd get 'em from energy suspension since i need new bushings for the sway bar anywho...
and where did you pay 25 bucks for each side? junk yard? are there any internet sites out there that supply 'em? thanx.
Theyre brackets much like the rear sway bar brackets (looks like -u- ) shaped should come with the lca's and endlinks, other than that ur good to go.
I got mine from a friend, shouldnt be that much from a yard somewhere, or see if anyones selling some in calssifieds.
oh, ok..i know what you are talking about...those U shaped things...so thats it, huh? the integra/civic si/ex front LCAs fit with the stock civic ball joint? did all integras have front sway bars? or atleast the holes for sway bars? werd.
Yea all tegs came with them on the front, yes theyre bascially the same hub/spindle so everything is interchangeable.
Tuner Eddy
13
12-22-2007 06:01 AM
