Help -Wiring Harness...
I have a P28 ECU w/ Skunk2 OBD2-OBD1 harness, that's all fine and dandy.
Now the issue is using a D16Y7 wiring harness in the bay with the B18C5, the car is a 99 DX Hatch. Now I know the easy resolve is to get a 99-00 Si Wiring harness, but that's not an option with cash. Plus we removed the wiring by the crank pully and put it on the C5 and some other harness. Sooo, if ANYONE can give me a diagram of pins or what wires to extend/create or whatever I need to do this then we'll be able to figure it out.
Thanks guys in advance.
Re: Help -Wiring Harness... (citrEK)
12 views and no posts... i thought this was the place to come for help.
This is what I got from a local shop, tell me if this sounds right.
B12 Pin = VTEC Solenoid
C10 Pin = VTEC Pressure
C3 Pin = Knock Sensor
2 Pin plug on IAC - use only the yellow w/ black stripe wire on engine harness to one pin on this plug + new wire from other pin on this plug to B23
AllMotorNoPower
07-10-2017 08:24 AM
daniel990836
03-17-2008 07:30 PM
