Fixing camber? HELP!!!
Basiclly what I am trying to find out is how to fix camber. I have a 95 Civic Ex Coupe w/ B18c1 if that really matters. I recently changed my tires they were completly worn on the inner part of the tire(front only). I had a wheel alignment done today and was told that the camber and the caster were off and there was no way to adjust it. I dont know if I am right or anything but I thought I saw on the board ways to fix it.
Thanks in advance guys
Re: Fixing camber? HELP!!! (SOHC_MShue)
like he said u need a camber kit if your car is dropped more than 1.5" u need one of these. The car kit for all 4 wheels is about 100.00 bucks u can get them at http://www.ebay.com
i got some car seats in the back and all i hear is daddy go faster
Re: (lsvtec hatch05)
I couldnt figure that out myself. Car is pretty much stock suspension. I have gsr webs on it but other then that I dont have much.
Re: (BADGUYNY)
I had inner wear on one of my tires when I got my car, too. I figure either the car was dropped before I got it, or the wheels were on a different car that was dropped at some point. With stock suspension, just get an alignment and you should have no more camber wear problems other than whats already worn on your tires.
toe is the biggest comcern when it comes to tire wear!!!! if the inside of your tires were totlly wasted most likely you cars front end was toe'd way out which will show as a -number also if it was only a little out and you never rotated your tires they could be trashed just as easy... type in your alignment print out so we can see the whole truth....
Re:
I have the actual figures from the alignment here they are:
Front Left: camber -0.3 caster 0.5 Toe -5.07 Front Right camber -2.0 caster -0.8 toe 2.79
Dont know what to do will the camber kit actually work?
it is possible that the car has been wrecked before?????
i would look into a set of adjustable upper control arms you will be able to make that much adjustment with them...
and yes it was toed out alot
itsJDMyo
13
01-07-2005 10:40 AM
SRd240sx
11
05-05-2003 09:45 AM
