URGENT knock sensor wiring
Old 10-18-2003, 04:30 PM
Dat Dere Cell Tech
daklown's Avatar
Default URGENT knock sensor wiring
Alright, i need to know EVERYTHING about hooking up my knock sensor. ITs a 95 EX and im putting B16a2 in it. What wires do i have to run, where do i run them to/from on each harness, etc. I dont know anything at all about this and im tryna get the car done tonight
Old 10-18-2003, 04:37 PM
flat-blk-HB's Avatar
Default Re: URGENT knock sensor wiring (daklown)
You have the KS? The plug? If so then run the wire to D3 at the ECU. I believe you will have to add a pin, or atleast I did in my car. If you dont have the plug there is other Honda Plugs that will work, most of them being 2 wires but you only need one and it will still work as long as you make sure the one you are running to the ECU is the one making contact in the female part of the KS.....Sorry if I did not make it clear enough
Old 10-18-2003, 04:42 PM
Dat Dere Cell Tech
daklown's Avatar
What color wire do i run to D3 ?
Where is D3 ? how do i find it ?
And can i fund this wire by the harness plugs by the strut tower ?
beginmyhonda
07-29-2009 02:14 PM
crxb16ftw
05-23-2007 09:32 PM
EGTHU6
07-28-2004 01:50 AM
98AccordEX
09-01-2003 02:27 PM
devonic
10
04-09-2003 09:53 AM
Quick Reply: URGENT knock sensor wiring
