how do i wire the evap soleniod? help
motor: usdm 95 b18c1
ecu: usdm p72
car: 92 cx
im using an EX engine harness and the clip that was for the evap solenoid i used it and plugged it to the IAB canister(under the IM) i also moved pin a20 to a17. Now, i went to the junkyard got my self the Evap purge and an extra clip. ok there are 2 wires can i just run one wire directly to a20 which i believe is the pinout of the evap on the ecu. and for the other wire can i just splice the black wire that im using for the IABs? where should i run the other wire to.
ecu: usdm p72
car: 92 cx
streetstylenperformance
02-26-2004 03:28 PM
