96 CIVIC DX - radiator shoots out water
Old 01-25-2013, 09:41 AM
raider1qaz's Avatar
Icon3 96 CIVIC DX - radiator shoots out water
Well my radiator shoots out water so i changed the cap and it helped but it still builds up a lot of pressure and over heats, i have to keep adding water to keep it normal. A friend said it might be something with the cylinder header but i have no idea AND AT STOP LIGHTS SOMETIMES IT JUST DIES, ITS A AUTOMATIC. FIRST I STOP AND THEN IT SHAKES AND TURNS OFF AND TAKES A MIN TO TURN ON AGAIN.anY ADVICE?would be a lot of help thanks guys
Old 01-25-2013, 10:56 AM
kyden's Avatar
Default Re: 1996 HONDA CIVIC DX PROBLEMS!!!
sounds like you have a blown headgasket.
Old 01-25-2013, 06:49 PM
BumperHumper307's Avatar
I agree it sounds like a blown HG, did you check the oil and see if it looks milky?
Old 01-25-2013, 06:53 PM
raider1qaz's Avatar
thats what my friend said it might be a blown head gasket, he checked the oil and said its not milky yet. So i should change the hear gasket?
raider1qaz's Avatar
that sounds about right
Old 01-25-2013, 09:11 PM
ameer_vtec99's Avatar
Default Re: 96 CIVIC DX - radiator shoots out water
i have the same problem i just changed the head gasket
Old 01-26-2013, 05:07 PM
raider1qaz's Avatar
when changing the HG did it help??
Old 01-26-2013, 05:25 PM
The Grumpiest
grumblemarc's Avatar
This is not the only indicator of a blown headgasket.
Old 01-26-2013, 07:46 PM
I did not say that it was the only indicator. One step at a time. Is there a reason you go to my post and talk about what I say over helping the person that needs help?
Old 01-26-2013, 08:36 PM
raider1qaz's Avatar
Old 01-27-2013, 02:55 AM
The Grumpiest
Because you offer that up as if that's the only thing to check. If it isn't the only indicator then why do you not list the other things that should be done/checked? How about to a compression test to make sure? That's why the OP must know that no milky oil doesn't mean it's not a headgasket issue. It could be a cracked block. it could be a warped head considering the OP continues to drive and overheat the engine. I would submit that it's PAST being a head gasket issue so my comment is relevant.
Old 01-29-2013, 05:18 AM
ok I see what you mean. I stated the milky oil as something for him to check, I should have listed many other things and didn't. I am sorry for not giving a better list of things to check. I am here to help and learn, not to cause problems or to start fights.
Old 01-29-2013, 06:16 AM
strategy400's Avatar
A compression test could also come up normal and you may still have a leaky headgasket. I agree that if OP has been continuing to drive an overheating car with possibly contaminated fluids there may be many more issues than just the headgasket now.
Zgembo
05-03-2015 05:51 AM
ssj4trunks09
19
01-13-2008 04:21 PM
slickciv
08-28-2007 02:22 PM
killacam661
05-04-2007 05:18 PM
thehondabuddy
04-13-2005 01:09 PM
Quick Reply: 96 CIVIC DX - radiator shoots out water
