Passanger window loose
I have a 97 Civic Coupe. Electric windows. The Passanger window was off track on top where the seal is on the outside. Just the corner was like sticking out of the track. I removed the door panel and rolled the window down and pushed the window back into the track. The window channel was still in place no issue. I rolled the window up halfway and i can move the entire window left and right in the track. I seen the 2 bolts on the bottom and got the window into position and they were loose so i tightened them up but the window still moves left and right. I was looking around why its still doing this but it appears the bar infront of the window i assume for the regulator is moving also with the window. Does this mean i need to get a new regulator or is there other bolts in there i can tighten to keep the window from moving back and forth so it will stay in the track? Thanks
TwoKSiR
11-04-2007 02:33 PM
00ekcoupe
13
08-27-2005 10:52 AM
samson1
06-21-2004 08:35 AM
