need wiring help- trailer lights!
95 honda del sol. Yes del sol. I have a tiny trailer to pull behind it, and i need help wiring it up. The trailer uses a typical flat 4 plug. Green, Yellow, Brown, White. Id like to splice into the del sol's brake light harness, but the colors are different. I used this:
http://www.etrailer.com/faq-wiring.aspx
and it didnt seem to work. The brake lights stay on, turn signals dont work right.
Re: need wiring help- trailer lights!
you need a signal combining box to properly handle the separate brake and turn signals
here is one choice
http://www.etrailer.com/Wiring/Tow-Ready/119130.html
Or the no cut version:
http://www.etrailer.com/Custom-Fit-V...cleid=19955863
here is one choice
I got this
no cut version but i cannot figure out how to use it! it plugs in to the harness, however the only places it will plug in, i would need to disconnect the taillight on that side, and it wont plug back into it (it is not a "T" like i had imagined.
taynom
12-22-2016 08:08 AM
